94' cobra loss of power when warm?
BranSVT
Massachusetts
Hey guys, I've been having an issue with my 94' cobra. Original 5.0, stock upper/lower, old autologic chip, SVO Aluminum heads, cammed, BBK Cold air. Runs great for the first 5-10 minutes, pulls really hard starting at 2300-2500 RPM, then when it gets warmer, I only make power around 3000+ RPM and it also feels like some power was lost. It even has a different exhaust tone. Any ideas?
95GT86SS
Coil or distributor. My 95 would do that til I swapped out the distributor.
95 GT BBK CAI TB MSD 6AL O/R H SLP LM1
Coming soon GT40 Heads Intake and e303 cam with Long tubes
Or IAT or CTS sensor is failed/failing and it's pulling timing. I think you can test them with an ohm meter.
BranSVT
BranSVT
Massachusetts
Interesting. I have a street fire coil, and an MSD pro billet distributor. I have no idea how many miles are on them because I didn't install them. The car has 130k on odo. As far as those sensors, I'll see if I can find a way to test them. Thanks for the suggestions so far guys!
lutter94
South Dakota
That MSD coil will fail you. I promise. They used to make great stuff, and I think their dizzys are still good. But there's a lot of bad reviews of their coils. I had one melt/crack the case and leak transformer oil out of it. A generic auto parts store unit is much better. I learned from experience.
95GT86SS
I got the same coil. No issues yet
07GtS197
Fort Myers, Fl
I hear the same stuff about msd, their stuff is really hit or miss. Ive heard with coils its oem or nothing. Still Id check all the sensors first and pull codes before replacing stuff.
BranSVT
BranSVT
Massachusetts
Inspected the cap/rotor/dizzy, took some pics. From the looks, the rust/corrosion could definitely be causing issues. What do you guys suggest? Whole new distrubutor?
95GT86SS
Jesus.... put in the dizzy too
95GT86SS
Rich porter reman
evilcw311
Most Evil Member!
Louisville, KY
Much easier to drop n a rich porter than it is to rebuild these
BranSVT
BranSVT
Massachusetts
That's so good to hear.. Haha, where can I find remanned rich porters for 94-95s without vacuum advance?
95GT86SS
I got a RP in my car with no issues now.
Kiswoc
