94 Cobra project
RAU03MACH
NEW MEXICO
Ok, fuse fixed it.....for now!
Next question, time for exhaust.....what flowmaster set up do I want to sound the best and make the most noise? Also H pipe or X pipe. More concerned about sound than I am performance. Plan is exhaust, 3:73 gear and then E303 cam.
So what do you guys think? BBK H-pipe and Flowmaster American Thunder exhaust?
If you go to the post a pic of your ride as it sits post
I just posted a short video clip of my 95 gt mustang
It has flowmaster super 44 with H pipe
And b303 came with 30x Ford racing heads and a gt40 intake
The video is clear and is a real deep sound
Close to what your asking about
skidoojunky
Awesome! Thanks!
skidoojunky
Thanks for sharing! Your car looks and sounds great! Could almost pass for twins with mine.
So what is the difference between the E303 and B303 cam? Your car is built almost identical to how I would like mine to be.
RAU03MACH
NEW MEXICO
I would have to look the specs for you I have all Ford cam specs
I do know the E303 has a bit more thump to it requires more upgrades
The B303 is easy to tune without a lot of upgrades
I will look for the specs that way you can see the difference
Looking forward to checking out your ride
RAU03MACH
NEW MEXICO
The Ford Racing Camshaft Specification chart describes individual cams currently available from Ford Racing.
Refer to page 84 for performance characteristics and usage guidelines. See page 121 for valve springs.
SMALL BLOCK V8 HYDRAULIC ROLLER TA PPET CAMSHAFTS
Intake Events E xhaust Events Duration Lift
Rocker (0.050") (0.050") (SAE) (inches) Lobe Center
Part Number E ngine R atio Op en Cl ose Op en Cl ose Int. E xh. Lobe V alve Int. E xh.
M-6250-B303*
1985 and 1.60 5° BTC 39° ABC 49° BBC 5° BTC 284° 284° .300 I .480 I 107° 117°
➀ ➁ ➂ ➅ Later 302 224° 224° .300 E .480 E
Roller Cam
M-6250-E303 1985 and 1.60 0° BTC 40° ABC 40° BBC 0° BTC 282° 282° .311 I .498 I 110° 110°
➀ ➁ ➂ ➅ ➆ Later 302 220° 220° .311 E .498 E
Roller Cam
M-6250-F303* 1985 and 1.60 4° BTC 42° ABC 52° BBC 6° BTC 288° 288° .320 I .512 I 109° 119°
➀ ➁ ➂ ➃ ➅ ➇ Later 302 226° 226° .320 E .512 E
Roller Cam
M-6250-X303* 1985 and 1.60 5° BTC 39° ABC 49° BBC 5° BTC 286° 286° .339 I .542 I 107° 117°
➀ ➁ ➂ ➃ ➅ ➈ Later 302 224° 224° .339 E .542 E
Roller Cam
M-6250-Z303* 1985 and 1.60 7° BTC 41° ABC 51° BBC 3° ATC 290° 290° .345 I .552 I 107° 117°
➀ ➁ ➂ ➃ ➄ ➅ ➉ Later 302 228° 228° .345 E .552 E
Roller Cam
NOTE :
Camshaft intake and exhaust valve events are measured at 0.050" tappet lift. The
duration figures in the shaded area are taken at 0.050" tappet lift. This is useful to check
the cam with a degree wheel during installation. The solid color is advertised duration. For
comparison purposes, add intake and exhaust lobe centers and divide by 2 to calculate
“camshaft lobe separation” specification for Ford Racing camshafts.
NOTES :
➀ On EFI engines, performance camshafts work only with mass air induction
systems. Will not work with Explorer EEC-V EFI.
➁ Also fits 1994-1997 351W with factory roller cam when used with mass air EFI.
➂ Stock 5.0L HO cam advertised specs are 266°/266° duration, 0.444"/0.444" lift.
➃ May require piston modification for piston-to-valve clearance. Valve clearance
should be checked.
➄ May require longer push rods.
➅ Hi-Stall torque converter recommended for automatic trans.
➆ Emissions legal with 5-speed manual trans. E.O. #D-225-16.
➇ Great for superchargers. Manual transmission recommended.
➈ Good torque and power up to 6200 rpm. Manual transmission recommended.
➉ Good torque and power up to 6500 rpm. Manual transmission recommened.
RAU03MACH
NEW MEXICO
I just posted the cam specs for you
skidoojunky
Thanks a ton for the cam specs. Torn between the E and B series cams.....we will see..
Been a while since I posted. Been crazy busy with post harvest fertilizer applications. Had a rain last weekend so Devin and I put the BBK off road H pipe and Flowmaster American Thunder exhaust system on. Devin was a huge help and learned a lot.
skidoojunky
The whole plan with this project was for he and I to bond, him to learn and incentive for him to stay out of trouble and keep his grades up and if he holds up his end of the deal when he turns 16 it’s his car. So far so good.....he made honor roll the first quarter of 4th grade and missed high honor roll by .48% in reading. Not too shabby.....dads happy anyway...
Oh yeah, there may be an ulterior motive for dad to have something to beat on till he turns 16......but that’s our secret.
skidoojunky
We decided on personalized plates and I let Devin pic what they said. He is a wrestler and he is part of an elite group of little bad asses in east central Illinois called “STORM”. Since the car is the same color as his team colors he chose “94 STORM” as is first pic. The plates came yesterday and to our dismay they came as our second pick....94 DRE.....Devin and I share the same initials so it’s all good!
skidoojunky
Another 3” of rain today so no field work tomorrow, weather permitting we are all going as a family to the Urbana Firefighters car show and trunk-or-treat event for some fall fun.
I also got new headlights, corner lights, brake pedal and clutch pedal pads along with a new grill emblem. They all still need installed.
