Oct 4, 2012 #1 T The Midnight New Member Joined Aug 31, 2012 Messages 9 Reaction score 0 Rough idle and acceleration, I have changed the plugs, wires, cap and rotor and cleaned the MAF sensor, any ideas what it could be?
Oct 4, 2012 #2 CC'S95GT Post Whore Joined Apr 19, 2008 Messages 10,715 Reaction score 178 Location Hampton ,Ga. dirty fuel filter? Clogged cats? do you have any mods? have you tried to pull codes? you can have a code set without the CEL being on.
Oct 5, 2012 #3 Mustanger Well-Known Member Joined Dec 3, 2006 Messages 2,294 Reaction score 122 Location Southern Oregon The pickup on the distributor? That fixed mine, same symptoms
Oct 9, 2012 #4 C Curry_Hurry New Member Joined Oct 6, 2012 Messages 6 Reaction score 0 Location Alberta, Canada Possible vacuum leak as well. If you have a scanner check the IAC counts. If not use a can of brake clean, spray around intake/vacuum lines and if rpms increase there you go.
