94 one piece top
akaslick15
just ordered the one piece top for my 94 gt and its pretty nice
just had couple questions
is it hard to do? is it a do it yourself thing cuz it says the one piece top is half the time to do other then the two piece
does anybody have a write up on this ??
they wanna charge me 600 just to put it on and they can screw there self cuz im not gunna pay a penny
toyman
What do you mean by a one piece top? Does it have a plastic rear window instead of the glass insert? Good luck on the install. I wouldn't touch that job. It's not by any stretch easy. I'm sure others will give you their experiences.
ivan12
Any way you can upgrade to glass? That plastic yellows pretty quick and looks really shi**y. Instead of getting a new cover, I hunted down a parts car and replaced the whole thing. It took my brother and me about 2 hours.
I think someone here posted a link to ehow to how they did their install.
ivan12
No, it's just unbolting stuff and putting back on, would've been less if I didn't have a styling bar to remove. Once you remove the rear seat and the rear panels it's pretty straight forward
ivan12
^^^ my thoughts exactly. This is a mistake that will cost you a new top in the future
Adam95GT
I did mine and it turned out ok after several trys...
OK so here is some things you will need to do you top. These are just my recommendations.
1.Buy new tacking strip for the header bow and A frame (where the pads connect) Can be found here: Convertible Tops and Convertible Top Parts
2. Your going to need a Pneumatic stapler to make the job easier.
3. An electric impact gun or air wratchet is nice to zip on and off the nuts for the times your going to need to test fit.
4. You will need a 12pt 14mm Socket to remove the nuts holding the tacking strip to the body.
5. i think a T8,T9,T10,T15,T20 will cover all the torx for the liner and seals.
6. A big torx to undo the rear seatbelts T60 IIRC???
7. Various sizes of staples the oem top uses 3 sizes... I bought 1/4'' 3/8'' and 1/2''
8. Chalk helps to draw lines on the top if you need to make adjustments.
9. Spray adhesive (super77) or contact cement.
10. A sharp blade to make the cuts in the top. I prefer a xacto to a box cutter... If you cut to far the tops basically trash.
11. A drill to drill out the old rivets holding the tacking strips to the A Frame
12. A rivet gun and rivets to install the new tacking strips.
13. A set of picks to remove staples.
14. A coat hanger and some string to install the cables
15. Blankets to save your paint.
Tips:
1. Make sure the rear window is mounted high enough (mine is a little to low)
2. Make sure all staples are fully in when stapled. If not and you try to tap them in with a hammer you will make a small cut in the top... I got one in mine.
3. BE EXTREMELY CAREFUL WITH THE WEATHER STRIPPING ITS NOT CHEAP!
For the $125 i spent on the top and $50 in supplies im happy with it. its not a pro job but it looks decent and the window is actually in place...
It will wrinkle and look like trash if not done right... In which case you need to pull out all 100 staples you just put in and restaple the damn thing.
Finished:
Im confident if i had to do it again it would turn out much better.
5litrarag
Adam, how do those exterior trim pieces come off right at the 1/4 windows? Do you need to pull the interior panels to get access? I have the middle one off and am trying to decide when and if I need to pull the rear interior panels out to get the other ones so I can refinish them. I was gonna do them on the car, but decided that is some ghetto $hit and figured I want to do it right.
Adam95GT
akaslick15
akaslick15
damn how can i thank you any more thanks bro but i got the top from convertibletopguys and im going
to exchange it for the canvas two top with defrost option window i say what the hell another 300 bucks
wont hurt but im loving this write up here bro and i just had talked to my guy and turns out his cuzin owns
a shop that does tops and custom interior and he said return the top and get the canvas top cuz you wont
regret it and he said 300 for the labor so i guess im just going with that plan
btw dont you just love the laser red on the stang have it on my car not sure if thats the color tho lol
akaslick15
akaslick15
btw adam had you ever had problems on your latch the two things that lock the top i mean do those things
break easily cause the driver side is fine but the other wont lock up right i wanna try to fix it my self cuz
each latch is like 149 dollars lol
Adam95GT
Just figured you might be talking about the rear trim pieces... You need to unbolt the big one from the rear (open the trunk)
The interior panels need to come out of the back. The rubber window trim pulls off and there are 2 phillips screws to take off the metal trim...
I man have pics somewhere
Adam95GT
They break because people pull on the latches and not on the frame. You can adjust them loosen the hex set screw then the hooks screw in and out.
