95 Cobra w/ fox S-trim
STL Mike
95 Cobra. Only running an alternator, no smog pump. Looking at buying an S-trim off a fox.
Can I switch to a fox timing cover to make the brackets work? Any interference issues w/ pullies, fan, etc???
Thx,
Mike
Blakonblak94
I assumed that the bracketry is actually what keeps you from bolting it up. The pulley setup for fox is different all together.
STL Mike
I should have also stated that I'll be changing over to the vortech fox pulley setup as well as the timing cover.
Does the fox blower bracket put the alternator down low?
Blakonblak94
That I don't know. If it's passenger mout I would assume so. Are you replacing all
The front brackets with the fox setup?
MikeF
you will need a spacer on the crank pully.I purchased a complete fox V1 also thinking it would bolt up but I got the correct monting kit and lower pully for the 94/95 after talking with vortech but I wish I would have tried it with fox brackets and crank spacer.good luck give us a report how it goes
mikey94gt
The alternator goes underneath the blower on the FOx setup. You could probably get the blower bracket for the 94/95 for about the same $ as the FOX accy drive system, and save some headache.
