New build. 95 GT 347 Stroker
Wells.Strength
Wells.Strength
Michigan
The TH400 is a proven component! Very tough! Ive witnessed a handful of friends pour money into ford auto transmission only to give up and swap to a TH400, their problems were solved afterwards
This is the hard truth I didn't want to face lol. They most definitely have been proven, it's just the adaptation that has me hesitant, learning all of this and doing it on my own tends to lead to buying the wrong parts or having to order parts during the install. I have made a cheat sheet so far for the TH400, bell housing, crank adapter, flex plate, TC etc. I have the superbell, PRW 164 tooth flex plate, snout adapter for GM TC to SBF, and then figuring out the custom driveshaft all on my list. With all of that the $$$ adds up, I was just hoping that someone would tell me the Lentech 4R70W rated at 1500hp would be good to go! It does come with a full manual valve body and trans brake, and custom TC. $4550 for the trans, and $14-1600 for TC. https://lentechautomatics.com/pricing/
Wells.Strength
Wells.Strength
Michigan
14$ for a TC is an absolute steal, why are you complaining lol
LMAO
LOL YEAH.. "354WHP".... RIGHT. That dyno is lying to you. Unless the Th400 really does suck up that much power. A stick car would probably be 75 more.
Yea the Dyno numbers were useless, the dyno itself was priceless though the tune was dialed in perfectly. Definitely more HP to the ground that the Mustang Dyno said, but we knew that. The guy who dynoed it actually predicted me running a 11.9 he was spot on, even with the shit transmission, which is still the 4R70W, haven't switched to the TH400 yet. That will help a ton, and I am switching to the Box R intake and a TFS-51403005 Cam. If I could find someone who wanted these parts I am taking out that would help a ton, but no such luck so far.
Wells.Strength
Wells.Strength
Michigan
Inside still needs some work, left the radio out for more gauges. B&M ratchet shifter was a nice upgrade no more blowing past 2nd gear! Need to do something else with that nitrous gauge, was thinking of moving that to the radio bezel.
Wells.Strength
Wells.Strength
Michigan
Since I can’t post in the marketplace yet… I’m going to post this here. For sale. Best offer takes it and pays shipping. 75mm
Wells.Strength
Wells.Strength
Michigan
Couple updates. Box R purchased, powerglide with manual valve body and transbrake, drive shaft, all other trans parts etc. new upgraded cam as well.
Wells.Strength
Wells.Strength
Michigan
Track heat intake, and Trickflow track max stage two cam for sale, along with the 75mm throttle body, running a 90 now.
Wells.Strength
Wells.Strength
Michigan
Another new update... added twin 73mm precision turbos after all of the previous upgrades. So with that I have went to dual 455 pumps in a 15 gallon fuel cell, new 6an to 8an fuel lines, 2200cc injectors. And switched to E85. First start up was Sunday! And it sounds NASTY!!
Wells.Strength
Wells.Strength
Michigan
Few updated pictures. working on a video upload.
Mikehonco69
