95Grandtouring5.0
- Joined
- Aug 30, 2006
- Messages
- 1,094
- Reaction score
- 1
I have a 95 GT mustang, I did a HCI swap about a year ago. I had the car dyno tuned. Car put down 281rwhp and 305rwtq on a dyno jet.
For a good long while, the exhaust smells absolutely terrible, extremely rich.
Took it to the track last night, and the best time I could muster up was a 13.9 @ 100. The track I race at is only a hundred foot or two above sea level.
The past month or so, the CEL has been coming on after driving the car for about 10 minutes or so. As well for probably 5 months, the surging idle and rich smell has been there. At first I thought maybe the chip erased itself, but that can not be, because before it got tuned it was way worse then it is now, but its not perfect like it was after the tune. Several people told me the iac is probably bad which would be my surging idle problem ( only happens when it is cold out), but I don't think that has anything to do with the issue of it running so rich.
The main mod's are as follows
BBK CAI
BBK SSI Intake manifold ( modified for a sn95)
Trickflow twisted wedge street heat heads ( I believe 160 or 165cc) 2.02 valve
Trickflow Stage 2 camshaft
30lb Injectors
BBK fuel rails
BBK adjustable fuel pressure regulator
BBK ceramic Equal length headers, bbk high flow catted H pipe, mac cat back
BBK 70MM TB
BBK under drive pulleys
SCT Chip, custom dyno tuned.
Any help is appreciated, I wanna get this thing running right.
BBK CAI
30lb Injectors
BBK fuel rails
BBK 70MM TB
