95 gt mustang problems
CrazyPerson
currently having charge problems with my girls car.
Here is the problems i am having:
Its having charging issues with the altenator. somedays the car works fine then other days the altenator wont charge the battery. i have replaced the altenator and battery and it still does this problem. i have also gotten them both tested, they are both ok.
I can only think of converting it to a foxbody computer to fix this problem? anyone else get this problem?
C
CrazyPerson
i forgot to mention that the battery ends up going dead. then i have to jumpstart it, then it works fine for a couple days. then stops charging again
Paul
That has nothing to do with your computer. Something is up in the charging system. On foxbody cars, there is a tiny resistor on the back of the gauge cluster - if it is not there, or is malfunctioning, the battery won't charge.
That is almost certainly NOT your problem, but I suck at electrical. :)
1quk50
maybe something is being left on? like a light... does it have a system? maybe something is being left on...
ck all the battery cables for corrosion inside the insulation. make sure all the gounds are in good shape too. there shouldn't be any paint or grease under the connections. interior lights is a good thing to ck too, sunvisors, hood, trunk,
ram360
like paul said, sure as hell isn't your computer! You have a short somewhere causing a draw on the battery when the car is off.
C
CrazyPerson
it doesnt charge while the car is on to. somedays the altenator charges the battery and other days the altenator doesnt charge the battery. while driving the guage fluxuates sometimes
GDTrumbo
Nashville, TN
I wonder if it was having a good day when it was tested. The fluctuating gauge condition really makes me think the alternators internal regulator is
not functioning correctly.
GT
Yellow94gt
Sounds to me like the car has a draw somewhere... check all the ground straps from battery back, check for corrosion inside all the battery cables going everywhere and check any exposed hot wires in the car... mine had a draw through the radio and would kill the car after a couple days.
95 svt cobra
You def have a draw coming somewhere, do you have any aftermarket stuff? alarm, amp, etc? mine was doing something similar and it turned out to be the POS alarm the previous owner installed. Major pain to unfuck the hillbilly wiring job
BigginSN95
mine started charging poorly after i put the under drive pulleys on it it would fluctuate and sometimes left my battery dead. just a thought.
