95 gt sputtering and backfiring every shift.. HELPPPP!!!
aaron89
my 95 gt is having a sputtering and backfiring problem... when you first crank it up in the morning it runs like crap! i have to rev the motor up seriously about to 4500 rpm to get it moving then it till about a quarter of the way through each gear then it clears. until u hit the next gear and it does it again... sputters and if you floor it, it backfires then takes off spinning when it starts to run right... but if i run it about a good hour or so it will clear up mostly.. ive changed everything from fuel pump to sensors.. cleaned out my mass air flow, and cleaned every connector under my hood and no codes besides the egr but i have no smog or emissions lol.. just cant seem to pinpoint the problem, i will keep updating if i find out anything.. do the same for me please... and im also running rich.. maybe this will help eliminate some things.. also changed tps, rotor cap and button. checking my plug gaps now..​
ademily87
CHARLESTON, SC
Get a fuel pressure gauge and fire her up. See what its at at idle then try to make it visible and take it for a spin with the gauge connected.
Sent from my ADR6400L using Tapatalk 2
Nacho98
Why not just take it to a shop and let them figure it out? Makes no sense to be a backyard mechanic replacing everything under the sun that doesn't need replacing...just throwing money away compared to a diagnostic charge.
A
aaron89
well i enjoy fixing my own car, i definitely see your point but its 17 years old and just wanted to replace some of the old elctronics anyway.. just pulled my plugs and the back two cylinders on driver side were wet and funky... gonna replace and see.. just got this car back not too long ago and it had "NEW WIRES AND PLUGS"................ so he said.......
A
aaron89
yes coil has been replaced.. and sorry new at this whole messaging thing lol what the hell is PIP or TFI... sorry...........lol
PIP- Profile ignition pickup- It's the electronics inside your distributor. It's a known trouble area on 94-95 5.0's. How old is your distribtuor?
TFI- Thick film ignition- aka ICM- Ignition control module. It's a known trouble area on fox 5.0's. but not so much on sn's.
Back firing sounds like a timing problem. double ck your plug wires are correct.
What is the timing set to? Did you pull the spout?
A
aaron89
timed it over and over again.. hoping something would change... still the same... its on 10 advanced now but ive tried 14 and 16 and 10 retarted. no change. checked distributor everything looked good....
what exactly "everything" that you replaced.
You probaly know , you need 3 things for ignition. Air, fuel, and spark.
Air is easy.
Fuel, you need 40psi with vacuum disconnected at the regulator, also you can ck to see if the injectors are firing with a noid tester.
Spark, spark at the plug, a Haynes/Chilton manual gives a procedure to test the coil.
Another common problem is ground wires from engine to frame, frame to body, frame to engine, battery to engine, computer to body, etc.
Ninety8stang
Duh405
You could always try cleaning the MAF off as well. Couldnt hurt anything and it's free/cheap
A
aaron89
cleaned the MAF also.. will look into the grounds and fuel pressure... thanks everyone...!
