96blak54 2001 Cobra
07GtS197
Fort Myers, Fl
The pressure plate in my old 07 gt grenaded on my way home one day and I lost the pedal. Kind of strange yours still returns. Anyway, most places I’ve seen say either valeo or parts store clutch unless you’re making big power.
white95
Apex Junky
Admin
Prairieville, LA
On the way home today while hammering out some rpm's and speed.....i lost the clutch. It must have flew apart or something. Clutch pedal still returns to the top position, so i dont think its a cable or quadrant. I can rev the engine and float into a gear but when releasing the clutch, all kinds of noises be coming from it.
Clutch recommendations?
I had real good luck with an Exedy 500 clutch/Fidanza billet flywheel combination in the S197. Worked well NA and never slipped behind the M122 combo.
96blak54
96blak54
Staff member
Lawrenceburg Kentucky
I got up on jackstands, transmission removed and clutch swapped with a parts store "upgrade". The 28K mile stock clutch disk came apart. Not the 1st time ive seen and heard of cobra clutches of this year not holding up. I didnt replace the throwout bearing, it felt good. Clutch cable felt good too.
Got the car down and went to reconnect the negative battery terminal and the factory terminal strap broke....grrrrrrr. So I swapped it out in favor of a lead wing nut type. I peeled the old strap terminal off the ground wires and crimped on a heavy 2ga copper lug that would slip over the wing nut terminal. Now to remove the negative ground battery terminal, all I need to do is spin off the wing nut.
Car started right up. I pulled up on the clutch pedal to set the cable tension and wallha......car moved. Clutch is a bit grabby, but thats to be expected.
Out driving around, car felt good and very strong! I do believe the 3000miles I have drove the car, the clutch had some upper rpm slippage because now she pulls real good!
Now that the car is together I have come to the conclusion to sell it. Id love to keep it, but the desire to be out of a few bills out weigh keeping it and I can restructure some other areas of projects,
Musturd
96blak54
96blak54
Staff member
RIGHT!
My thoughts exactly!
I mean, the car looks awesome! Dang near mint! Once they looked at the milage, they were all over it!
Letting it go was a sad day! Knowing my dad purchased the car for me to eventually acquire had its pains, because a convertible Mustang Cobra just simply wasnt his type of transportation. He drove many other vehicle types since the cobra purchase and all were practical transportations. At the end of the day, Im glad I let it go. I have to much going on in life to care for the car like it needed to be. Besides I still have the '96 Gt.... that my dad bought for me.
Musturd
RIGHT!
Yea i would have kept it being it was from my dad . Seeing you still got one from him that’s awesome . My dad passed away a few years Back so lots of sentimental vehicles im keeping as he was my best friend .
badass98svt
The inner rim wasnt machined or clear coated, so i chose to use a wire wheel brush with a drill to make clean up quick. I have a brass wire wheel brush on order to polish up the rough texture that the steel brush wheel created and them ill ceramic coat or clear coat. Price is a factor. I know them ceramic coatings get very pricey. The price alone has steered me away from use, which leads me to ask, what brand do you recommend?
How did you make out with all this. I totally missed your reply. My apologies.
I use G Techniq for ceramic wheel coating. It seems to be a great product and very easy to apply. I think it's about $50. Keep in mind a GOOD can of clear (2k Clear) is upwards of $30 anyway. Don't use parts store clear. Definitely use 2K Clear. You'll thank me later. (If you didn't already finish them up)
Lucky57
