sequential tail lights 2001 cobra
lking78
many thanks for your help -- all the kits i saw excluded the 2001 cobra -- seemed to be a wiring issue -- anybody know of a solution or workaround ?
Mustang5L5
The turn signals on the 2001 Cobra are different. They are a separate amber section of the housing with only two segments, vs blinking the 3 red segments like the standard models have.
The kits out there are setup to blink 3 segments, so you need to find someone who can make a two segment sequencer.
they make a kit that doesn't have the harnesses on it and you would have to cut/connect them. Just take one wire at a time and it is not that hard. I got a kit a few years back for a project I never did and have it sitting here if you want to make an offer. It is supposed to be for a 96-04 mustang
L
lking78
ttocs -- sorry -- i just now saw your post -- apologizes for not responding sooner --
i found a sequential kit from CARiD.com -- https://www.carid.com/spec-d/product-mpn-lt-mst99rgled-sq-tm.html?singleid=1209040286
and it fits great -- the only problem is that the connectors don't marry up -- their tech support people are looking at the problem -- seems to me the simplest route is to cut off the male end of the connector from the old tail light -- figure out which 4 wires on the OEM to connect to the 4 wires on the sequential light -- cut off the sequential connector and connect the wires -- but we'll see --
there are lots of sequential tail light kits out there but all others specifically excluded the 2001 cobra model -- there apparently is something 'unique' about the wiring -- this was the only kit that swore it would fit a 2001 cobra --
L
lking78
according to the manufacturer of the tail lights -- they are incompatible -- apparently the 2001 cobra is the only mustang that you can't put sequential lights on -- i am too new to all of this to understand why -- if there is anyone out there who would be willing to educate me on why -- it would be greatly appreciated -- many thanks
07GtS197
Fort Myers, Fl
That’s because, as others said, the 99/01 cobras have a seperate amber turn signal unlike the rest of the 99-04’s that have all red brake lights that also act as the turn signal. They are integrated. Since the 99/01 cobras don’t use the tail lights as the turn signals, they can’t use a sequential harness.
L
lking78
thank you both very much for the help -- breathe in, breathe out, move on .....
