98 4.6 2v timing help
austinw88
South Carolina
Putting newer heads on my 98 gt 4.6 2v, just going back with the npi heads due to financial reasons. I already have the heads and all required gaskets, my main concern is timing I've done some research and I've come up with what I believe is correct. Both timing marks on the cams should be around 11 o'clock with the timing mark on the balancer on TDC. Is this correct?
D3VST8R96GT
Marble Fall, AZ
Damn. Its easier if the components get market and its disassembled at RDC. I can't recall off the top of my head. I'll have to dig into my note book. Unless one of the smart guys here can remember.
Copper links were at like 11 and 1 o'clock damn it's been a really long time since I tore into a 2V, I need to rip mine apart soon.
punched281
Colorado
And just a warning, when you turn the motor over by hand, it takes like 40-something rotations to get everything lined up again.
austinw88
austinw88
South Carolina
Thanks for the help guys, I figured it out now. I was looking and looking for the copper links in my chains but they wore off i guess but i did find 2 black links on each chain so i believe im good to go now
austinw88
austinw88
South Carolina
ok i have the motor in time where all marks line up but on the guide side of the chains are not tight. timing chains wore out?
D3VST8R96GT
Marble Fall, AZ
Stretch chain length wise making 2 parallel chain lines with one connecting link at each end, then paint the end links. Put your timing marks there
Put them links on the timing marks on the sprockets
No brainer and your good to go
Also don't forget, on the left side (driver side) sprocket there is a raised piece, that is the trigger for the cam sensor NOT the timing mark. You want the timing chain lined up on the dot on the cam sprocket.
Post up some pictures when you think you are getting close and we can all look at it and let you know if it's set correctly.
austinw88
austinw88
South Carolina
I marked the chain like that and lined everything up and to get the slack out of the driver side chain i had to turn the cam. otherwise there would be a ton of slack on the wrong side.
hazel113
