98 gt tach wire??
dutch2081
ok i will be installing my nos rpm window switch, my question is i need to tie into a tach wire. Anyone know of an easy spot under the hood to get the tack source??
thanks in advance
dutch2081
thats cool looks like alot of bs tho...cant i get it off one of the coil packs??
DeepList
Auburn, IN
It's not as complicated as it looks. It would actually be a lot easier (and cleaner) to just remove the bezel and cluster and just tap into the tach wire with a splice connector vs running extra wires into the engine compartment.
chris91
Cincinnati, OH
Dont use a splice connector. They are junk and WILL come apart eventually. Do it right and cut some of the insulation away and solder it.
