A/C clutch removal?
showoff
how do i remove the ac clutch pulley? is it pressed on and i just need a puller? or is there more to it?
wayne94mustang
without doing it again i cant tell you how, but it was easy as hell.
seems to me you just unbolt like 3 little bolts and maybe a take a clip off.... maybe it was 1 little bolt right in the center.
all i know is it was simple.
showoff
i removed the one center bolt and the pulley would'nt come off easily. i was thinking i might need a pulling tool.
modo
Philadelphia, PA
i would think the sn compressor is the same as the fox so here goes. there is a nut and a lock washer on the shaft holding the clutch on. there is a puller that threads to the clutch but you can get it off without the puller by carfeully using a screw driver. if you want to get the pulley off there is a snap ring holding that on from the inside of the pulley
