A/F ratio gauge.
k0walski
i have a A/F ratio gauge sitting around from my old car and my car has a BBK catted X pipe, do they have the o2 sensors in the front?
toyman
Are you using narrow or wide band O2 sensors? An AFR gauge for narrow band has no meaningful output.
shock357
The light-show makes panties drop pretty fast...
Paul
K
k0walski
i got everything hooked up. il post pics later. its a narrowband i had lying around i did it for the lulz and panty drop effect. figured why not had it lyin around. feeding those wires thru the firewall can be annoying
vermilion
maryland
if you are insisting to use a wideband. i HIGHLY recommend
with this instrument i have fixed countless installation issues. my next is a vac/boost gauge.
