about to do a TON and pilot bearing replacement
Madbum90
I'm about to change my throw out bearing and pilot bearing. It sounds like the bearings are squeaky and it's twitchy when engaging the clutch. Also the clutch pedal shakes and vibrates when the pedal is halfway to the floor. Does this sound the tob? And any good write ups or tips when doing it? Thanks first time taking out a transmission and clutch.
It does sound like a TOB.
Your Haynes/Chilton manual will walk you through it.
Once the tranny is out take a good look at the rear main seal and replace it also if needed.
Madbum90
Thanks man, also I forgot to mention it's hard to get driving because it shakes the car and wants to stall, and when you down shift it makes a loud screeching noise. In reverse it's even worse it's almost impossible to drive it. It makes clunking noises and a reaches as well.
Musturd
The easiest way I've found to get a pilot bearing out is the wet paper trick , you rip up small pieces of wet paper and jam them in behind the pilot bearing and then use a rod of some sort . A extension works great , this truck works almost instantly .
RichV
CO
I would suggest to do it all. Buy a clutch kit, most come with pilot/throw out. Have the flywheel surfaced, and be done.
What year/model?
sounds like the clutch has gotted hot and glazed the flywheel and that's why it's shaking the car.
As Rich just said, do it all while your in there. It's not hard to drop the tranny just a pita and time consuming.
Musturd
Usually when the cars shaking you end up wit a sweet looking pressure plate that's cracked in a few spots
Madbum90
Could the rear end be a culprit to why it whines like a supercharger when I down shift? And why it's harder to drive in reverse
RichV
CO
Some oils like to whine in the rears as well. I had RoyalPurple in my SVO and it was very whiney. Replaced it with some Valvoline with LSD and it's been quiet since.
Vmarch
