ABS Code 61 repair
96SN95
I have a 96 GT that is giving an ABS code 61 (abs pump/abs pump relay fault). Anyone had this and know what the most common repair will correct it? I cannot find an ABS relay anywhere on the car, is it integrated into the pump assembly? I dont hear the pump "test cycle" during the vehicle start system test.
pp_puncher
I have not had this problem, but I know where the abs relay is. It is under your steering column and knee bolster. It is a small black box and it will be stamped ABS. It is $124.00 at Napa. I'm sure you could find someone local to swap one with to test.
96SN95
EXCELLENT....FINALLY SOMEONE WILLING TO SHARE SOME KNOWLEDGE!
Thanks very much, now I have a project for the weekend!!!!
