ABS light is on
ucjattriskey510
so today i just got my car back after changing the harmonic balancer and d car runs like brand new.. but another problem is that the ABS light remains on now... how do i fix this?? and my heater doesnt work on any mode except that it only defrost d front windshield...if i turn the knob left to right, its just goes straight to windshield defroster....problemssssss
Paul
The thin vacuum line protruding from the passenger side of the firewall and proceeding toward the vacuum tree on the driver side has likely been broken or pierced. Fix the vacuum leak and your heater should blow out the floor vents again.
Win
Kennesaw, Ga
You can also check your ABS Sensor behind your spindle. I had mine light up after i first got my old Vert and i took the wheel off and cleaned it off with a little BPC and it went off and then i scanned it and nothing.... Just my .02
94 DropTop
I might have to try that on my. My light cam on and my abs started fucking up so i just pulled the fuse and deal with the light. my CEL is on to cuz i took out my smog pump.
eliyarbrough
Nocona, TX
Huh, mine's been on for about 2-4 years?  I had it scanned & I need a new sensor.  It just flashes away.  I'm kinda used to it by now.  It was going to be like $125!!  I could spend that on so much more.  I don't need any air bags!!
Win
Kennesaw, Ga
94 DropTop said:
I might have to try that on my. My light cam on and my abs started ******* up so i just pulled the fuse and deal with the light. my CEL is on to cuz i took out my smog pump.
Yeah the reason i tried it was that when i braked hard it would grab then just randomly start shuddering and doing all sorts of things crazy so i tried it and it worked...
Win
Kennesaw, Ga
Air bags ??? I thought ABS was Anti-lock braking system
SoddyRebel
mine stays on both on my old 97, and my 95. Anyone got a pic of where the sensor is so i kno what to clean.
Win
Kennesaw, Ga
94kingcbra
wow that's the same problem I have! abs light on and defrost only! If you find out what it is I would like to know. Good Luck!
Win
Kennesaw, Ga
No problem ..... :) It's easy when your car is up on jack stands :) I guess its harder to have motivation when you have another car to drive
eliyarbrough
Nocona, TX
95convgt, yeah I had both flashing! I see from my car stuff, on 7/31/06 I had an ABS sensor put in! I had that one fixed though! Sorry, I got confused!!
yea that defroster prob is the vacuum line along the back of the fire wall. like paul said in the 3rd reply
fixthedoor
If the ABS light came on immediately after you installed the harmonic damper then maybe you did not hook everything up properly. If so did you retrace your steps?
extreme_21
Mtl, Canada
You could always jump the DLC for the ABS in the engine bay near the fuse box, thus if there's any stored codes the ABS light will flash the fault/faults stored. Jump terminals #2(org/wt) and #6(blk) at ABS DLC. Once DLC is jumped, turn ignition on, ABS light in dash will begin to flash. If there's any fault/faults stored they will be displayed but only once..hehe so don't mess up or you'll have to start all over. If there's no fault stored, ABS will flash code #12 then remain on untill ignition is turned off and jumper wire is removed.
Here's some ABS codes I have on-hand:
12(system ok)
19(ABS Control Module)
22(RF Valve)
24(LH Valve)
26(Rear ABS Valve)
31(RF Wheel Sensor)
32(RR Wheel Sensor)
33(LF Wheel Sensor)
34(LR Wheel Sensor)
41(RF Wheel Sensor)
42(RR Wheel Sensor)
43(LF Wheel Sensor)
44(LR Wheel Sensor)
61(Pump Motor/Motor Relay)
63(Voltage Interruption)
69(Low Voltage)
78(Sensor Frequency)
LAFENATU
You may have hit one of the ABS wires.
Like said previously, find out if it is flashing codes or it could be the ABS control unit tends to die everyonce in a while. It is behind the radiator on the passanger side.
