Adding key Fob. NOT programming
Caboose302
Dayton Oh
I did a search and everything came up for PROGRAMMING a remote,but did every SN95 come with key fobs? My car doesn't have one and I like to add it, But I know GM cars have a special RPO code to state wether a Fob can be used. Do ours have that too?
chris91
Cincinnati, OH
Look in the trunk behind the driver side liner. There should be a black box in there if your car had keyless from the factory I do believe.
Caboose302
Caboose302
Dayton Oh
Ok thank you! I don't see why it wouldn't. It has most of the other options, including the 17" wheel package. Ill check tomorrow when it's light out.
it was an add-on option that people had to pay extra for. Normally if it had factory keyless you would have a remote.
chris91
Cincinnati, OH
Unless you bought it from a used lot and they lost the remotes. lol
Seen that happen COUNTLESS times working as a lot tech in my teen years.
Twista
No black box.. just get a alarm..you'll have keyless then. My 95 gt has no box either
* Sent from tapatalk while sitting on the toilet at work*
Caboose302
Caboose302
Dayton Oh
I did some more digging an asked a friend of mine that works at ford. I was hoping you could just plug and play with the RKE module but its a completely different wiring harness. I'm planning on buying a high end alarm anyway, but I'm just going to have to save up for it, so a factory RKE would have been nice to have in the meantime.
TLSF150
Was there nothing behind your drivers side trunk panel or just no black box?
If your car came equipped with anti theft like mine you will have a yellow box like this instead of the black box..
If you have this your still in luck if theres nothing back there then your going to have to add an aftermarket alarm
Sent from my Galaxy S3 using Tapatalk 2!
TLSF150
And yeah I know my trunk is dirty AF lol
Caboose302
Caboose302
Dayton Oh
Nah there's nothing. No box, mount, or loose connectors. It'd be nice to have it, but not with as much trouble as it'd be. Ill just get an aftermarket alarm. I'm just a little OCD about wiring in my car.
sn95jones
Arlington, Tx
So wait im confused what's the difference between the keyless and antitheft. Because my car has the factory alarm and keyless entry
Sent from my HTC One using Tapatalk 4 Beta
sn95jones
Arlington, Tx
