adding power along with bling????
g36 monkey
Orlando, Fl
[/URL][/IMG]
pi motor from an 02 with trick flow valve covers and some other polt ons...with hi teach cames pulls 281whp and 300wtq....and the bling would be the sound the cams give...saweeeeeeeeeeeeeeeet..........
Do something about those wires!! lol
g36 monkey
Orlando, Fl
Clean them up. They look so jumbled there in front of the intake. Just get some nice separators, or do the trick I am fond of.
Take a zip tie, wrap it around the whole lot, then put a zip tie between each one as a separator. It looks quite nice and you can use it on any wire/vacuum hose. Not to mention you can get crazy with color coordinating, etc.
dutch2081
ya that was an old pic.....here is how it looks now after the no2 install....little better with the wires but still not happy i m missing that bracket for the alt..
Polished supercharger is a good idea.
This car was parked next to me last weekend and it got a lot of looks.
If you want to clean it up a bit and do a PI swap, here's what you can do.
Paint the new valve covers
Paint the intake manifold like slow90coupe did on his
And here's some more stuff that you can probably do in the future to clean it up
Tony
Tony
ohio
[MENTION=15502]Ferocious[/MENTION] i did a couple of those.
Hmmm. I hadn't seen your engine in a while.
A PI swap with a cop conversion and battery relocation would probably make that thing instantly stand out.
MustangChris
Aurora, CO
t-dog:
#1)
you can paint your heads.
#2)
you can add chrome valve covers (be sure to count the number of mounting holes on whatever heads you end up using)
http://www.americanmuscle.com/bbk-valvecovers-chrome-v8pass1.html
#3)
you can powder-coat your headers while the heads are out. (they have a shiny powder-coat similar to chrome)
#4
you can powder coat your intake manifold cross-over.
#5
you can buy a chrome/polished throttle body and plenum
http://www.dragonperformance.net/catalog.htm
thats about it when swapping heads on a 2v, brotha.
Tony
Tony
ohio
with pi heads and intake...can i just pick any intake for a pi motor? i've seen some pretty nasty ones.
what intake is that? also is that all upper intake, lol? or is it an intake plus a plenum. i'm gay..i dont know :(
That's a bullit intake manifold + upper plenum + throttle body.
However, I do believe you need PI heads for this intake to work.
Trick flow makes a similar setup for 2v's.
Yes. And PI heads will give you more options.
Tony
Tony
ohio
ok, i kinda thought so but was'nt sure..thanks steven
