Advice on what to pick
Mean98GT
With taking all my current mods into consideration (in sig). What upper intake do you guys suggest and what cams should I look into?
duff daddy
Dalamar said:
How bout the new Trick Flow heads and IM? :thumbsup:
that is ALOT of money, and remember you have to use THEIR cams because of the intake valve location change... until someone does a custom grind and then moves it
+1. plust he already has the heads.....
i just dont understand who would put on a PI head and no PI IM?
sbr420a
well his sig says bbk throttle body. so maybe get a accufab or professional products
Pennywise2
MustangChris said:
PP = Poor Production. id never buy anything from them (personally.)
Bullitt intake and Comp XE268AH cams.
I agree Chris I unfortunately had a 75mm Professional Products throttle body on my last
mustang.The butterfly on the throttle body opening would stick open and at idle the rpm
would stay at two thousand rpm.I installed the stock Ford 65mm throttle body and my problem
went away.After trying everything I could never fix the problems I had with the 75mm Professional
Products throttle body I had. I ended up throwing it in the garbage can.
I also would never purchase anything from Professional Products in my opnion.
Do a search and you will see that other mustang enthusiasts have had problems with Professional Products
too.There products are made in China.
JerZeyStangz
Northern NJ
I read a few articles on these heads, and they never mentioned that you have to use their cam(s). If that was the case these heads would be pita because you need those cams. On mm&ff, they swapped out the ported PI heads for these heads and left his blower cams for his car, so I dont know for sure what your talking about unless I just dont know correct me if im wrong.
Trickflow twist wedge 2v Heads with comp 270's...
Cammed 02 Mustang GT
duff daddy
no your right, i was thinking wrong. they juts swap the HLA and teh valve to make it work... my bad
JerZeyStangz
Northern NJ
Ah cool. Thanks for confirming!
