alternator(fuel pump)
96sn95gt
ok i went to advance and my alt has 5amps and 10amps on load is that bad??????????? i think it is cus they looked it up and it said 130 amp
bobtsgt
If thats all its putting out then yes the alternator is about dead. Time for a replacement. A good alternator test is to start the car then pull the negative off the battery. If the car dies then the alternator isn't putting out the appropriate voltage and amps causing the car to die.
