greenscobie86
Hey all,
Writing this post in aggravation(sort of :BangHead
So I've gone through literally 4 alternators(rebuilt ones) in the course of 4 months...
I've chalked the first couple up to bad rebuilds but now I'm suspecting that the car is to blame for frying these things lol.
It seems that the voltage regulators fail and the alternator stops charging after about 2~3000 miles of use.
I'm pretty much at a loss here:
All the wiring looks great.
The battery Isn't shorted and is in good shape.(I've had it tested under load/no load and CCA on a professional tester)
The car is literally stock electrics-wise. No big aftermarket radios or alarm systems. The only non stock stuff is the LED's in the cluster...
One thing to note, the tach needle in my car acts really funky at times. I'll explain:
Most of the time it simply doesn't respond and sits at 0 RPM.
Sometimes it likes to make a complete 360deg revolution and gets pegged at the opposite end of the tach.
Sometimes(rarely) it actually works good.
My knowledge of the tach is that it may be tied to the voltage regulator to receive the RPM signal, is this true?
Finally has anyone had a similar problem on a 96Cobra(or any other stang for that matter) that can provide some input?
This swapping alternators is starting to wear me down, sure I can change them in 10 minutes flat now, but my mechanic is growing tired of getting me warrantied replacements...
Thanks in advance!!!
