alternator overdrive pulleys
warrior86
I've read people get these usually after getting UDP's due to having a system or whatever.
Now, in my case, I dont have UDP's but as reported in a previous trend im having issues sometimes with my car not seeming like its getting enough power after say turning the car off... going into a store.. and coming out a short time later (lets say i do this 3 or 4 times in a row within a short period of time)...
now I do have a System. 1000 W AMP with 2 (10s).. and i do blast it.
Could I just buy an overdrive pulley without having an UDP and see if that helps my situation?
If so, will I need a different size serpentine belt for this?
you might try a smaller pulley first. (smaller makes it turn faster) but likely you'll have to buy a higher output alt.
W
warrior86
are you referring to buying an UDP first and then an ODP?
If not, arent ODPs already smaller than stock anyway?
typically udp's slow all the accessories down. i wouldn't suggest udp's in your case. i would say try an odp first on the alt. and if that doesn't work then you'll have to upgrade to a higher output alt.
