aluminum driveshaft
shine1stang
yes the driveshaft will fit. Assuming that the yoke is from the same tranny that you have. Meaning that if the driveshaft is pulled from a 5 speed car that it will fit a 5 speed v6, same with aod, aodes. If you have a c4 then a t-5 driveshaft will work
1slosn95
i put the driveshaft in just had to change out the yoke that connects to the transmission. I would definately have to say it feels alot better through out. :coolsmiley:
shine1stang
Awesome man!!! Glad to hear it worked out for you. Most of the time its just a yoke swap and your off and running again. I just picked up an aluminum ds for $25. Its about 4 inches too long but i know probably one of the best welders that will cut it down, weld and balance it. Then ill be rockin too!
