And the PI Swap Begins...
96gt226410
Today at work, I had some down time so I seperated and labeled all of the gaskets and seals and I also disassembled one of the PI heads I bought. Everyting was clean. I think I'm going to replace the valve seals while it's apart just for that reason. I hot tanked the head for three hours, cleaned all the valves, and I'm soaking the lifters (followers) and rollers in oil overnight. Here's a quick picture of the head disassembled after I got it out of the tank. They still look a little dirty, it's just a bad pic (it was from my phone)...
ROB 98GT
Looks like alot of fun!!! It sounds like you know what your doing there. O0 Let us know how it goes!!
freefallin98
Lol you wanna do P.I. swap for me? Haha just playin. Looks like its coming along well thouh. Good luck and keep posting pics and info!
Tornbetween2
^ plus one to that. i have all the parts. i need to get my heads hot tanked. you want to do it for me
96gt226410
96gt226410
I'll do it for both of you. O0 You guys near Raleigh, NC? :)
You'll love it when you done.
Good luck :thumb:
Pennywise2
Good luck man with your PI swap.
It is alot of work but in the end you will like your mustang alot more.
Adam
Did you get the different timing cover bolts for those Windsor heads?
96gt226410
96gt226410
All I have left to get it those 10 mm bolts and a thermostat gasket. I have everything else. :dancing6:
96gt226410
96gt226410
Work has been real busy lately. My new valve seals arrived today. I also used the valve compound to clean up the seats on the heads. The way I did it was an older method. I put the lapping compund on the valve where it seats, stuck it in the matching bore and on the other side, I used my electric srewdriver with a piece of vacuum hose attatched to the valve and screwdriver. Then I just lightly spun it and tapped the seats until they looked like new. I don't have a picture of this, but I will take it when I do the other head. I'm currently regrinding the exhaust valves because they were pitted. I'll get done one of these days. :).. Here's a picture of the new valve seals and lifters that went in today...
96gt226410
96gt226410
Re: And the PI Swap Begins... With New Pics
I regrinded all of the valves, cleaned the heads, hot tanked them, soaked the lifters and rockers in oil for a few days, and leak tested them. The heads are finally ready to be put in. O0... In 2 weeks, these will be going in. Here's where I'm at now...
*I'm a little pissed, though. I have a set of BBK LT's and a set of 3.73s that I wanted to put in while doing the head swap. I ran out of funds, though. I still need a few things:
-a new mid pipe for the LTs, EGR delete kit, tuner, Speed Cal, stage 8 header bolts, header gaskets, and the bearing kit for the rear. I fell about $600 shy. :'(... Oh well, the PI swap will have to hold me over until I can get the rest done. :dancing6:
senior001
