07GtS197
That’s true but the point is you don’t need to get a certain value for closed throttle. Maybe some aftermarket sensors are scaled wrong so when they are at rest then read too high voltage for the ecu to be happy. On the other hand, that can also happen because the mounting point is fixed but the blade can be adjusted causing a different than stock reading when someone messes with the blade stop because they’re having issues. Most of these cars have probably had the throttle stop adjusted causing issues for the next owner.Not necessarily, as in my case, the voltage was too high. All I mean to say is different sensors will read differently, hence the need to adjust the blade sometimes.
