aode rebuild kits?
akaslick15
so guys my aode is basically gone i lost reverse and i would like to know what is needed for a complete rebuild and
where can i find a good rebuild kit for a 94 gt aode .im going turbo btw.. in the process =] so i need somthing good for about 450 hp and 520 tq give or take. somthing that will last and good for daily driving and wondering what stall
number to go with for a turbo setup and daily driver mostly street use.. high way runs but will take a lil abuse lol thanks guys... btw no 5 speed answers please.. to much traffic in chicago so im good..
forcefedhatch
Hmm I followed the tccoa jmod and teams build procedures for mine.. Works just fine!
Sent from my iPhone
forcefedhatch
Stall depends on your combo really.. My turbo starts to see boost around 2800 so I stalled to 2600 but for lager turbos I have always used a 300 rpm rule of thumb.. So if you start swing boost around 3500 go with a 3200 stall and a something like a 3:27 or so gear to put a slight load on the engine compared to a 3:31. But that's just what worked for me.. Others may agree but then again others may strongly disagree. Justy personal preference.
Sent from my iPhone
LAFENATU
Are you looking to have it rebuilt or are you asking for advice on a pre-built AODE like Performance Automatic?
LAFENATU
akaslick15, there are different ways you can go with an AODE. I can def help you with advice, I just need to know...
1. Budget
2. Real goals
3. Rebuilding or Purchasing a trans
akaslick15
akaslick15
well what ever u think that would break the bank.i just got a turbo kit so im looking for somthing that will hold to bout 500 hp 500tq somthing that i can drive on the street honestly my budget max would be 1300
LAFENATU
Well, $1300 is gonna be real tight but we can make it work. Keep in mind most places are around $400 for remove and re-install so I don't know if the $1300 includes parts or not.
You're going to need a hardened input shaft, a good clutch kit with kolene steels and a good torque converter at the minimum. One nice thing is Ford put a hardened input shaft in the 1998 and newer 4R70W which will work perfect in an AODE. There are 2 rebuild kits that I like, one kit that has Raybestos Blue Clutches and another kit that comes with Alto Red Clutches with the "Power-Pak", both come with Kolene steels and hi-performance front bands. I believe they stopped making the Raybestos Blue clutches but you can find them if you really look. Karl Baumann @ BEControls.com might still have them. Karl Baumann is crazy smart and an all around killer guy to know when it xomes to small block ford automatics.
Now, you need a converter. That is something where you're gonna want something in the 10" range. As far as the stall DO NOT go by internet recommendations. Call the companies and they will go over your modifications and THEY will decide and advise what stall to go wih. You're going to need something that has been furnace brazed and an anti-ballooning plate for boost.
If you have any more questions, don't be afraid to ask.
