decipha
none of that helps, i need an actual visual display of the components or even a wiring diagram will suffice
AFAIK it interrupts the TCIL and TCS (transmission control switch - o/d cancel) circuit for a monetary condition (TCS)
reason being is that the TCIL (transmission control indication lamp) is used by the the low speed fan
the trickery that henry did was allow a +12v to actuate the tcs and a ground out to actual tcil, that module should be nothing more than a couple transistors and maybe a relay or two depending on if they isolated the circuits (i suspect they did)
disabling the tcs and low speed fan should allow you to use the ecu without the module
