axle/differential
95BlkCobra
pasadena california
i posted last week about a break squeek after doing my rear brakes, well today we pulled the rears and noticed the rotor rubbing the caliper. we also noticed the driverside axle was moving around quite a bit more than the passenger. in total probably 1/8 of an inch. that was causing it to rub. so we called a trans/diff shop and the said switch the axles so we did and now everything seems to be fine but im taking it to a shop and having it looked over tomorrow. any idea what could cause this?
LAFENATU
Did you check to make sure the caliper itself wasn't bad or the caliper bracket? Then again you said the axle was moving as well right?
