Axle Question-Pro's needed!
Passenger
Ok so pro's aren't needed, just a very knowledgable person would work.
Long story short, either the hub, or axle shaft is bent on my passenger rear. Seeing as the hub is made onto the axle shaft, I've gotta replace the whole thing reguardless of which piece is bent.
I know axles earlier than 94, and later than 98 will not work. Because fox is shorter, new edge is wider. One of the local bone-yards here told me today that the 94-98 V6 cars have the same axle shafts and shit. I don't believe it, but its possible I suppose. Is there ANY OTHER car I can use axles from as a direct replacement? Don't have the cash to upgrade.
19mustang95
i'm pretty sure the 7.5" rear end in teh V6 uses the same axles as the 8.8" does, let me ask a friend to make sure.
2slo95fiveoh
Lawrence, Kansas
any 94-98 stang rear end will have the axles you need. also the square bodied rangers share the same axles, but i couldnt be for sure
on the years.
P
Passenger
So 94-98 V6 axles will hold my car? Didn't know if they would, or if they'd snap on the first launch.
