b cam in a 94?
coupe5ohh
Phoenix, Arizona, United States
any body have it? do u like it? hows the power range? lmk cause i was planning on ordering it this saturday and i wanna get a lil more input b4 i decide on wat cam i get..its either b303 or e303..nd ive heard nothing but good things bout the b303 and wanna c wat u guys have to say..its going to b going on a motor that will have tubular gt40 upper and a gt40 lower with gt40x alum heads with 1.7 rr
IceMan
Get the E303. I had a 94 GT that I bought with a B cam in it and it didn't make a big difference. If you are going to spend money get the E303.
mattm
i have a b 303 cam in my 95 gt with cast iron gt 40 heads n 95 cobra intke the car has a choppy idle n souds really good but i also went to a fox body ecm not sure how the 94 95 ecm would like it
T-5 Killer
Albuquerque, NM
coupe5ohh said:
bcam is .480/.480 and when i go to 1.7rr it will be .510/.510 and that will be with gt40x and have no piston nd valve clearance problems
This is the setup I have in my Cobra...I like it
BruhBrahBrad
Peter you dont listen. Why dont you get a tfs cam or a comp or a anderson or something...why a ford racing cam? If your gonna spend money, might as well make it worth it.
now that I think about it if it's gonna be a daily driver you're probably better off leaving the stock cam in there for now. Cams just seem to make the car less drivable and cause idling issues.
modo
Philadelphia, PA
its all in the tune. my small solid roller cam 232/242 @ .050 .603/.608 @ .050 112 ls 112 ic is a lot more radical then most out there and it drives and idles just fine
mattm
the 94 95 ecm is not big on cam swaps best thing i ever did was go to yhe old fox body computer i am runnin no tune n the car idles at 650 with a b303 cam sounds good n has good manners
T-5 Killer
Albuquerque, NM
What about for street legality (EMISSIONS) does the tfs,comp or a Anderson cams pass emissions. I know with the B-303 I pass with flying colors.
