Bad PIP help.
shock357
After replacing my cap/rotor/wires/plugs to fix my hesitation/stumbling problems, i finally decided to run the codes.
Got a bunch of EGR codes, which is a given, as they arnt even there :angel4:
But i also got a PIP failure code
The car will start and idle fine, but when i go to accelerate it will cut out, spit sputter, bog, break up, and try and die. It doesnt die on me in traffic, but after its warm and you try and restart it its slow(er) to crank over.
Car ran fine before, even made a 500 mile trip. i let it idle for about ~15 mins and then it started doing this.
Anyone got an opinion?
2002BLGT
Bedford VA
Get a reman distributor it will be easier to replace than tearing the distributor apart to put the PIP in your old one
depends on your budget and skill level.
$120 for a remanned, $20 for just the pip.
There is no easy way to replace the pip other that dissasemble the entire dizzy, and hopefully the bearing/ bushing isn't worn out too.
CanaryGT
Phoenix
Paul has a how to writeup in the How to section. I replaced mine. Its easy.
Dr Fildo
Jersey
I have had this pip issue 3 times. I just put in a reman. distributor from Advance Auto Parts - has a lifetime warrantee, and replacing the entire disrtibutor takes me 25 minutes. Anyone with the slightest mechanical know how could do it faster than that. If I ever have another problem...free replacement. Highly advisable if you have the $120.00 in my opinion. Whatever that's worth.
pontiacmike29
had the same promblem went to replace the pip itself and fudged it up i just went to advance and got a lifetime warranty dizzy for 90 its just easier
