bad shifting problems need help asap!
no_pistons7
alright i got some shifting issues with my car...at higher rpms i push in the clutch to change gears and it wont move, the shifter wont even budge until the rpms are lower like under 3000, recently changed the clutch but i dont remeber it doing it when we 1st changed it...ianno what is going on i took the short throw off and looked inside to see if there was any metal layin around in there or something but it all looks pretty normal from what i saw. wut else could this be cuz its pretty boring driving the car now knowing i cant shifter at rpms higher then 3000ish
vettekiller3
ya it sounds like a clutch disingadgment problem check the tension. did you change the throw out bearing? Is your clutch for bent?
916_5.0
I had a problem with my car not going into gear no matter how hard i tired, it turned out that my pilotlt bearing was trashed the bearing were not even in it anymore and they were all bent. I replaced that the clutch and TOB, along with the rear main cause i was down there.
vettekiller3
ya the best thing to do would be to drop the tranny and take a peak. check the throw out bearing the fork everything.
N
no_pistons7
the fork isnt bent but it couldnt be the cable not adjusted properly and the throw out bearing is making noise :knuppel2: im selling the car so i dont wanna drop the tranny again its a pain/hassle
