Frank.JD.Perez
:lewx4:
Photo bombing a recent photo shoot i was doing for a client and his car collection. Picture above is a Original Ford Cobra, worth a little over a million dollars.
Also got the cops called on my mustang yesterday after coming home from work. I guess my Stang is "Too Loud" and its a ongoing thing lol. I took it as a complement, surprised it took this long.
You get awesome shots man! Always a pleasure looking at your pics!
Thanks Tony, means a lot coming from you.
I wasn't even trying to get a good shot of my car just wanted one together with the cobra.
I like the back drops and how crisp your car looks. I gotta drive an hour to get away from stupid telephone poles lol. I have one pic that i counted 19 telephone poles in
Im curious Frank
Does "yasssssssss" sound like a real long excited "yes" or is it more like slag for "your ass"
its an solenoid/isolator that disconnects the batteries when the key is off to prevent them from fighting each other and draining one another. When you add a 2nd battery you are really supposed to go buy 2 batteries that match and install them both as well as this isolator but many people cheap out and just get one and add it to a half dead first battery and then no isolator. When one battery is stronger then the other the lower one will act as a drain or try to charge itself from the good battery. That drags the good one down but until its half dead they will "fight" each other electrically and you end up with a dead battery.
Best place to put the isolator is on the power wire leading up to them where its easy to split them off. I have my batteries in the trunk and have the isolator in the back seat area and then the power wires split off from there.
I added a switch on my console so I can use both batteries to start with if I need to just in case the starter battery is dead.
you would probably be better off and easier to to put it up front. You need to run one wire from the alt to the isolator, then from there another power wire to each battery fused as close to the battery as possible. You would be better off upgrading to 0 awg on the run from the alt to the isolator but its not extremely important if your not running some kind of high current system.
your is different then mine and what I am use too so for this one no you don't need a wire to the alt, just in between the batteries.
