bbk throttle body (sticking)
onelow2v
i have a 75mm bbk throttle body on my 2v. It seems to me like it is sticking when you are at a dead stop. I was wondering if anyone else have had these issues. I'm thinking its the bearings.
Thanks Greg
GENOS96
Beaumont, Alberta, Canada
Try some carburator cleaner both in and out. Also on my V6, the throttle cable had a fray right after it came out of its sleeve by the throttle body so it sometimes stuck partially open.
O
onelow2v
When im at a dead stop you have to give it a fair amount of gas to get any throttle response from it
lilj4u2njoy
Forest City, NC
I think it could be like a air lock, not sure of the technical name for it, but the suction could be holding it back, mine did this, I just adjusted the blade a little bit to we're it's slightly open, no more problem... U only have to adjust it a tiny bit
O
onelow2v
ill do that tomorrow while im at work to see if i fixes it at all thanks guys
FrankenStang
bum****egypt
i have the same problem with mine...it sticks shut.i even went and played with it under the hood testing it and yaaaa..i tried cleaning it,tried lubing it(yayayaya) and nothing helps..but it doesnt always do it
FrankenStang
bum****egypt
Yea like super tiny a 1/16th to 1/8th max
Wont that just raise his idle as it opens the throttleblade abit??? now taht you mention that that is waht corrected mine but i had to adjust my idle after the many mods and vaccum leak searching i had todo.
