BIG ELECTRICAL PROBLEM!!!??
94kingcbra
Alright, My 94 cobra is acting up. My dome light stopped working, and at the same time my electric locks stopped working. however if I use my alarm transmitter the doors will lock, but they won't unlock...Any Ideas? :help2:
forcefed5pt0
charlotte nc
Re: Stange Problem?
if you still have the factory keyless remote, the control module for them can make the door locks and dome lamps not work. do the map lamps work? found this in a repair manual, hope its a start.
94kingcbra
Re: Stange Problem?
Everything was working fine until I pulled my chip out of my pcm to send it back for a re-burn. I left the harness plugged in. I didn't touch any kind of wiring, all fuses are good, I just don't know where else to look or what could cause this....?
What do you mean by "map" lights?
94kingcbra
Re: Stange Problem?
Ok I got my chip today, I put it in, and took my car for a ride...While driving I noticed now my speedometer and odometer wern't working, my cd player wasn't working, my cigarette lighter wasn't working, and my brand new radar detector wasn't working....I re-checked all of my fuses everywhere, and not single has popped, same problems as above still happening. Oh and the map lights (duh) are also not working. I am a little worried now, someone please help....
bigjohnson4.6gt
Re: Stange Problem?
replace the fuses? my odometer/speedometer/radio werent working, then i replaced the fuses and they worked again. This does sound like a fuse problem to me
cntchds
+1. Everything you described sounds like it's Fuse related. Find a diagram and look for one that matches your symptoms.
Jerry santos
