Birel21y's 1994 Cobra 5.0 engine swap AND wire tuck
birel21y
Hi Guys,
I have been planning this project for some time now, and have never gotten to it with work and my road racing. I finally have some time over the winter to do an engine swap, so here it is.. :eek:ccasion14:
After 16 yrs of oil, dirt, etc. It was not a pretty sight.
2slo95fiveoh
Lawrence, Kansas
Re: Birel21y's 5.0 engine swap!!!
you're right, it wasn't a pretty sight, you didn't even have an upper intake manifold on the engine!! haha, looks like a fun project,
what are your plans for the replacement engine?
B
birel21y
Here is whats going in.
2000 Explorer long block
GT40 "p" Heads
light intake port job (gasket match heads, gaskets, and intake)
Crane 2040 PowerMax Cam
Billet true dual adjustable roller gears/chain
Cam timing advanced 2*
Flow Kooler High Vol. water pump
Melling high Vol. oil pump
Proform Pickup
Proform 7 qt. oil pan
Felpro 1 pc. silicone oil pan gasket
FMS lifters
FMS pushrods
Crane cams 1.7 rockers
Prothane Poly engine mounts
ARP bolts throughout
FMS black/red valve covers
TFS track heat intake
1" phenolic spacer
24 lb injectors
TFS valve spring kit w/ chromoly retainers
BBK 75mm TB
Summit 75mm MAF
Aluminum U/D pullies
Centerforce DF clutch
Findanza Aluminum F/W
Etc, Etc, ...
5.0kid
Re: Birel21y's 1994 Cobra 5.0 engine swap!!!
looks like a good project! is there a reason for going with the p heads over your gt40s? Do you have headers that will clear them? just wanted to check
good luck, and have fun with it
B
birel21y
I wanted to leave the long block alone.. and stock, plus my GT40's have a bunch of miles on them. I have a set of Hedman Long tubes that im going to make work. Mainly though, i wanted to do something different. Ive built 6-7 engines with the regular GT40's. Plus the P heads will have gobs of torque. :)
B
birel21y
Here is the destruction in my garage right now. (and this is after i cleaned)
3 5.0's in the garage right now. 2 are collecting dust :)
I love my tire mounter/balancer. No more $100 tire changes!!!
B
birel21y
Here is an update:
Got the Injector harness re-covered and installed. Upper intake is on, intake elbow is on, rebuilt my POS BBK throttle body that broke, Gasket matched my exhaust ports, Passenger side long tube header is installed, i have to beat the hell out of my D/S header on the #7 spark plug-all others are fine. Pullies installed.
B
birel21y
Here is the finished product...
B
birel21y
Update;
Longtubes fully installed, and heatwraped.
distributor painted and installed
Brackets painted and installed.
So basically the engine is ready to have the flywheel, clutch, bellhousing, etc put on and installed. BUT im not going to right away. My entire engine bay is going to be sanded, all small holes welded and painted. Wires ran through fenders, and carbon fiber panels covering where the battery and CA intake used to be.
B
birel21y
Here I decided to put a special touch on the brackets. I ground down the edges on the side...
Wires on. BIG THANKS TO HEATSHEILD PRODUCTS FOR THE 2" HIGH TEMP EXHAUST WRAP! THIS STUFF WORKS PHENOMENAL!
Steven
SC
Looks good man. Coming along for sure. Always worth it to take the time in the details.
B
birel21y
Alright, so i was up late last night, pulling off all the body work and fabbing up my opening for the fuse panel. This space will all be covered by a carbon fiber panel.
great work man.
that new motor looks hot!
PS. sweet tire machine. that's baller status.
B
birel21y
I just finished going through my engine bay. I wire tucked everything, and painted. I made carbon fiber panels to cover the areas where the battery and air box used to be... Its nice to work for a composite manufacturer. :)
bottlefed97
Orlando, FL
Nice work! You should definitely put a tubular k-member in while it's easy to do so with everything out of the way. It really makes things a million times easier to work on.
B
birel21y
Grr.. i wish i had the $$$. It would be soo easy to do it right now. :(
B
birel21y
Dalamar said:
great work man.
Thanks man, the tire machines are cool, until i have to move them to Seattle int he summer the mounter is nice and heavy :/
