OK so I've had a battery drain problem with my car and I narrowed it down to fuse #9 in the I/P Fuse Panel.
On this fuse circuit is the Brake On/Off (BOO) Switch, and Electronic flasher.
I'm pretty sure the electronic flasher is referring to the turn signal module thing. So I pulled that out and the drain remained. So logically I outruled that as a problem.
That leaves me with the BOO switch. From what I know it has something to do with the brakes and disengaging the torque converter or something along those lines?
Could someone elaborate on what this switch is, where it's located, and why it would cause a 2.2amp draw on the battery? What can I do to solve fix my problem?
