Bottle mounting (NOT TECH)
94 DropTop
Im full game to put it on a RSD if someone knows where one is that is actually secure and not made out of thin board that the bottle could rip out of, I dont have the stuff to make one myself and i dont want to spend lots of cash on one
1996mustangGT
I got an MMR one and took the cloth off, traced onto thin plywood, then put the cloth onto the plywood. Supports it fine, and also easy reach to turn the bottle on and off.
94 DropTop
cool ill look into that. My only other concern is getting the blow down tube out of the car. I ordered one to day so ill play around with it. How does the MMR one sit in the car?
1996mustangGT
For the nitrous line i took out the drain plug on the driver side to run into the car, then for the blowdown tube i went out the passenger side drain plug.
El_Diablo
interested?
El_Diablo
they're $275, two options... either the one you see or you can use his rear package panel instead of the stock one, to buy one you need to call 419-704-2686 and talk to scott
heres his website
http://www.scottrodfab.com/
94 DropTop
those are for coupes but im liking the trunk panels thanks for the cool link.
19mustang95
that's gay, put it in the trunk. you can fit the battery and the bottle back there. one on each side.
El_Diablo
sorry... didn't even think about the fact that you have a vert... either way, its not hard to fab something up
hell, use the lower seat belt bolts to secure it with some homemade brackets, if you have a hacksaw and a drill it can be done
for the front you can take the car to someone who welds and have them weld on some nuts if your that worried... the rear brackets should be enough though
94 DropTop
Im liking those trunk panels we will see, I might do a temp mount in the front just so i can spray it before it gets to cold here.
