Bottle users in HERE
Sn95Willis
Baytown Tx
Post pics of your under hood set-up and where your bottle is mounted.... I am in the process of putting the bottle on mine..
PLEASE!!!!!!
sbr420a
i will post up pics later for you. i mounted my bottle on my rear seat delete
Steven
SC
Steven
SC
I didn't feel safe having the bottle right there so close. Hence why it was mounted in the trunk.
El_Diablo
95opal.... how do you like the gauges being there? thats where im wanting to put my oil pressure (right side) and water temp (left side)
sbr420a
diablo thats where mine are at, i would opt for the pillar pod, the steering whel gets in my line of sight sometime.
95opal
I actually like the column pod cant get any more on my A-pillar as I am already running a triple there and I didnt like the idea of losing my clock for the pod, so the column pod seems to work just fine.
El_Diablo
the only issue with the pillar pod is the attention it gets.... i might just give in i guess but idk
Inspector13
Here is my setup.
It's a NX wet nitrous kit with a Trickflow plate system (mounted between the upper and lower intake).
(Never mind the water spots on the front of the engine. It's from the stupid opening on my hood scoop.)
As you can see it's all about stealth. :angel4:
97aztecgt
It was a 10lb bottle. I think it looks bigger in the picture though. I had it to where I could drop the back seat while sitting in the drivers seat and turn the bottle on.
Brenton
97aztecgt
When I got the car it came with it, but this is what the trunk looked like when I got it. It looked horrible, so that's when I made a new trunk floor and all that jazz.
Brenton
97blackout
You definetly made it look much better, putting that sub undeneath everything cleaned up the trunk nicely :)
Sn95Willis
Sn95Willis
Baytown Tx
Hey Brenton what did you use to do the trunk.. I am getting ready to make some thing for mine back there... Did you have to do it in 2 peices or did it fit in there in 1 piece??
