brake/blinker light problem please help
cody0170
ok so i have been trying to track where my problem is in my wiring. i dont have blinker, hazard or brake lights. but i do have parking lights. i replaced my fuse on my fuse block and changed out the signal flasher under the dash. had to purchase it threw ford for 30 bucks. still no lights. this is really getting frustrating. please help me out.
reivaxtorres
are you 100% sure you didnt blow the fuse again? or that you changed out the right one? mine blew once in the middle of the night coming downhill from a local mountain with cars following close behind, same symptoms you're having, and it was a blown fuse thats located under the dash/steering wheel.
C
cody0170
well found out that it was a fuse blown under the hood but replaced that and it blows a fuse under the dash everytime i touch the breaks. EVERYTIME. :(
96 blue moon
Have you done any kind of wiring to your brake lights? if not, it sounds like your BOO switch on the brake pedal is shorted to ground if you are blowing the fuse everytime you touch the brake pedal.
C
cody0170
hmm i talked to a electrician over the phone and he thought it might be a sensor to but something on under the hood like by the firewall towards the driverside. i forget the name tho.
Staff online
