bigjohnson4.6gt
- Joined
- Dec 23, 2006
- Messages
- 3,322
- Reaction score
- 0
its a 15mm bit, but i knew what you were talking about anyways
DFG_Pimpin said:94Vert said:DFG_Pimpin said:you have the right size torx socket right?
Their not torx, it's like 15 mm or close to it. Don't remove the torx bolts
or really, you are giving bad advice their boss...it is a torx and if i remember its a 50 or a 55. and ill put $100 on it that its a torx...unless my stock 96 brakes are special. :rollinglaugh:
94Vert said:Ok. well I guess the last two posts shows your wrong so I'll take the hundred.
DFG_Pimpin said:94Vert said:Ok. well I guess the last two posts shows your wrong so I'll take the hundred.
so i guess just me and this guy got special brake then huh?
http://mustangworld.com/ourpics/fcar/brakepad1.htm
Nightcrawler said:ehh you can do either or, if the torx bolt is stuck then take the caliper bracket off aswell. If you had the cobra brakes you can just pull the pin and it pops off.
