Building 2v 4.6 advice.
Hellspeaker
Alright im going to buy a 03-04 2v. My goal is to make around 350-400hp to the wheels n/a. I also want to run 93 octane if possible. So lets say i did all bolt-ons ad also did cams and heads. What would my estimated hp be after that with a good tune?
97stanger
I'm thinking you'll need some trickflow heads, all bolt ons, and check out VT, MHS, Comp cams for the best cam for your app
H
Hellspeaker
What kind of cams would you guys suggest? This is my first Mustang build here so i am pretty new to this.
duff daddy
with Ported PI heads, long tubes and Comp 270's on a stock 03/4 bottom end you will make 300 easy. If you do your homework get the TSF heads, the right cams, do a different manifold and make it work, you can hit it. Check out my build.
H
Hellspeaker
Already have my first victim lined up! Hes a 2v guy with a Vortech lol. He says his car runs 10's. This should prove to be quite interesting. I can already tell my summers going to be fun lol.
.357Magnum
I agree it is possible to get 350 to 400 na to the wheels out of a 2V. Cams, Heads, aluminum intake, full exhaust, custom tune, etc etc...But you will spend about the same or more as if you purchased a certain S/C. Above all do not forget about those gears and tires. You say he is running 10's? You will also need to drop a lot of weight off that car. I really do not think a 400hp na 99 to 04 stock weight Mustang GT will get into the 10's, but maybe I'm wrong.
97stanger
i mean, its possible to run 10s if all he tells you is he has a vortech
that means he should definitely be above 400rwhp
it all comes down to his suspension/tires, tuning, etc
at the same time, maybe hes running 13s
only one way to find out!
H
Hellspeaker
Yeah that's true. Yeah this will basically be my first build guys so im going to be on here everyday asking for help lol....so be ready!
