C4 trans and long headers
Lwiss
Quebec
Hi, my t5 recently broke and im in the process of building a C4, do you think long headers and a c4 will fit? they are bbk long headers,
I would think it fits but i have heard that some headers dont fit with some transmission.
95_BOSS
Cuba, MO
I know this doesn't answer your question....sorry
But can you still use the stock center console when switching to a C4 or does it all need to come out?
L
Lwiss
Quebec
ill have to remove it I think, because of the aftermarket shifter,
modo
Philadelphia, PA
what c4 are you working with? pan fill or case fill? 157 tooth or 164 tooth?
157 is tiny and will clear just about everything. b/m use to sell a shifter gate kit so you could use the stock shifter with a c4, even a reverse manual valve body one etc. i don't know if it is still available or not though. what you can do is something like i did back when i had a c4 and a power glide. i made a plate to mount the shifter below the trans tunnel then used a quarter stick shifter though the stock shift boot. car at a quick glance still looked like a 5 speed.
i will post some pictures later on tonight as im not home and i dont have access to the pictures.
