cam install.... HELP!
forkliftfixr
At what position is the cam location dowel supposed to be at? 12:00 -- 3:00 -- 6:00 -- 9:00
The timing gear I have has 3 holes in it, for the cam advance, Stock and retard positions, and I already tossed my stock timing gear unfortunately.
Im going off memory, but it was 3 months ago I took the cam out, but I "think" it was at the 3:00 position with #1 at TDC?
Heads are off so I cant go by the valves......
F
forkliftfixr
OnyxCobra said:
If you line up the 2 points on the gears it should only fit one way. I want to say it's the 6 o'clock position.
That would normally be correct, but the cam timing gear has 3 different holes on the back that the location pin can go into. There are 3 marks on the gear to align for either stock, retarded or advanced timing. I screwed up and pitched the stock cam timing chain gear so I dont have a refference now, and I forgot where that pin was in relation to the cam being set at TDC.
Yeah I could degree my cam also but there's still a dot on each gear that lines up so that it's straight. I'm 99% sure the dowel goes down and the lil notch on the crank goes up.
Mr. OAM
Just call the timing gear manufacturer with the part number. They can tell you without guessing.
Steve
