Cam suggestion
ride351
I have been waiting for a steeda 19 cam but I cannot find one as they have been out of stock for a while. I am looking for a cam suggestion for my about to be modified pony. she is mostly a fun street machine, but she might make it to the tracks (drag and SCCA) a few times :) Here are the Mods....
Ported upper and lower 95 cobra intake
gt40 heads off of a 95 cobra that have had work done (light milling and polishing and smoothing out the rough spots)
24 lbs injectors
K&N
pulleys
exhaust
gears 3.73
1.7 cobra RR
cam TBD
the car will be tuned
anything will be greatly appreciated!
ga94gt
So far I like my #19 but. If i were to by another OTS cam I would go with Anderson Ford. TFS stage 1 is good choice.
sbr420a
i had an e cam and i was one of the fortunate that didnt have a problem with it. but i am going to a tfs 2 cam
LAFENATU
Do you still have the stock springs on your heads? Your gonna want to replace the springs if you get a cam that has more than .500 lift.
2slo95fiveoh
Lawrence, Kansas
Here are some specs and prices:
(All specs are: Intake/Exhaust)
TFS1: $165
Duration- 221/225
Lift- 499/510
Steeda #19: $200
Duration- 220/226
Lift- 480/480
Ford Racing "E" cam: $210
Duration- 220/220
Lift- 498/498
Comp Cams (2 similar, only difference Duration)
$265
Duration- 212/218 or 218/224
Lift- 512/512
All would be good solutions.
Addermk2
TFS1: $165
Duration- 221/225
Lift- 499/510
Steeda #19: $200
Duration- 220/226
Lift- 480/480
Duration- 220/220
Lift- 498/498
$265
Lift- 512/512
both of the comp cams you listed are HORRIBLE recommendations, so is the E cam
XE276HR
300+ rwhp, here you come
2slo95fiveoh
Lawrence, Kansas
Sorry, I was just going with Cams with Similar numbers to compare too.
The XE276HR Cam sounds like it would be quite fun with
Duration- 276/282
Lift- 544/544
$300
But the initial post said he was looking into the Steeda #19, so i was just posting the more common similar choices.
Those lift numbers put it in a little more "aggressive" category, but i don't doubt that it will produce power and sound great too.
LAFENATU
Here are 2 cams designed for use with the 1.7 Rocker that have not been listed.
Crane 2031
214/220 @.050 .513/.529 112 LSA
AFM B21
218/226 @ 050 .542/.542 112 LSA
Addermk2
sbr420a said:
and you can got to like a .530 lift with stock springs
that would be pretty damn stupid. The stock springs are barely enough for the stock cam
hotrodheath
the crane 2031!! i have it in my car. awesome sound and power. i am really happy with it. my car has explorer style gt40 intake. gt40 heads with a little port work. bbk long tubes through h pipe with borla mufflers. this is an awesome cam!
LAFENATU
I have had a 2031 in 2 cars with great results.
The cam pushes hard on the exhaust side which 302 heads need.
sbr420a
did not say it was smart just feasable. they spings can hold up to a .540 lift.
5.0kid
i really liked the trickflow one when i had it, still have it if you're interested with less than 1400 miles on it.
LAFENATU
Problem is he has 1.7 rockers...in order for him to clear with that cam he is most likely going to need 1.6 rockers.
sbr420a
unless he was to buy spings then he should be ok
R
ride351
Thanks for all of the feedback guys. I have upgraded the springs (i was in there, why not)
