Cam suggestions?
auto_x5.0
I was looking at getting a new cam for the 5.0. I was looking at E303 or TFS stage 1, or even a F303. I was wondering what these cams are good for, and do I need to do anything else for these cams. And how do you guys like them if you used them.
Thanks
LAFENATU
A cam is only going to slow you down if you have a stock Intake/Heads.
You have a 5 speed or Auto??
A
auto_x5.0
Auto...but Im buying new heads and intake before I put it in. Im going to put them all in together.
LAFENATU
You'll need a torque converter too. The stock converter is not going to work well with an aftermarket cam at all.
A
auto_x5.0
I've looked and I can't seem to find a company that sells a torque converter for the AODE.
LAFENATU
There are tons mang. What is your budget? Are you looking to invest in a power adder??
A
auto_x5.0
Maybe later on...but that will be a long time down the road or I might go with 347.
LAFENATU
Well I would invest in a heavy duty converter now then, never wanna do the job twice.
What are you willing to spend?
x182dan
Make sure you plan on getting a tune after your cam install. Cause theres a good chance on whatever cam you get you'll have surging/idle issues.
A
auto_x5.0
I read your post x182dan about your sugring idle problems, thanks for your help.
And what will I be looking at for a good torque converter? Im not a big drag racer it will be a daily driven/autocross car. So it won't really be a hard driven car.
LAFENATU
Well I'm very satisfied with my Hughes Performance 11" 2500 stall HD converter. It rus about $500 but it is strong enough for any power adder and great for a street driven car.
J.R. Also does converters as far as I know...you may want to talk to him too.
A
auto_x5.0
J.R.? How would I get ahold of him? I was wol to go with a 2000-2500 stall converter. And you say 2500 works well on street driven cars, that's what I need.
LAFENATU
J.R. Is a member of the forum
J.R. Is his username
Check out the advertisement section. He posts here in the 94/95 section often.
A
auto_x5.0
Well that makes it easy. What rpm stall would you recomend for a daily driven car?
Steven
SC
2500 is not much different then the stock stall. it's useless to install a 2500 stall simply because stock is damn near 2500. 3000 is the best way to go.
A
auto_x5.0
This probably a sreally retarded question, but I'm new to mods. What exactly does a stall converter do?
LAFENATU
Steven, according to Performance Automatic..a stock AODE/4R70W converter is between 1600-1800. They said they have seen both.
2500 is no where near a stock stall.
You can't say a 3000 stall is his best choice. There are so many variables that come into play..rear gear ratio, engine size etc.
