Stage 1 npi cams are a waste of money. Stock Pi cams are almost the same size.
http://www.crower.com/cat/domestic/ford/mustang_camshafts.shtml
Yes,you will need to install new valve springs with the Crower 62811-2 (stage 2).96PonyGT said:so if i went stage 2 crowers I would need new springs? and what kind should I get? Im not too smart with the whole valve train thing so
any info will be great to know! any part numbers would be great too
Crower 26810-2 stage one NPI cams are the best cams to go with in your NPI cylinder heads.96PonyGT said:so what would be the best ones to go with, just some stage 1 NPI cams? I heard someone say that it is not worth it tho, is this true or will stage 1
npi cams work wonders still?
None of the cams you listed will work in your NPI cylinder heads because of toomy95gtstang said:ok i have a 1996 mustang gt auto, stock gears, remanufactored japser motor with bbk shorty headers, bbk catted xpipe, pi intake manifold, mac underdrive pullies. i was lookin at gettin a cam but wasnt sure on which to get. i was leaning for Comp Cams like a xe270 with .550 lift but i see everyone posting the VT Stage 1 or 2 cams. i wanted a cam with not as big as a lift as .550 because later on i would like to run a turbo setup and that lift is kinda big. what are yalls suggestions?
sound clips are accepted lol
Pennywise2 said:None of the cams you listed will work in your NPI cylinder heads because of toomy95gtstang said:ok i have a 1996 mustang gt auto, stock gears, remanufactored japser motor with bbk shorty headers, bbk catted xpipe, pi intake manifold, mac underdrive pullies. i was lookin at gettin a cam but wasnt sure on which to get. i was leaning for Comp Cams like a xe270 with .550 lift but i see everyone posting the VT Stage 1 or 2 cams. i wanted a cam with not as big as a lift as .550 because later on i would like to run a turbo setup and that lift is kinda big. what are yalls suggestions?
much lift on the exhaust lobe. :hammer:
If I were you I would go with Comp 262H's instead and plus
you will not need to install new valve springs.
Anything bigger than a Comp 262's and you will need new valve springs doesn'tmy95gtstang said:Pennywise2 said:None of the cams you listed will work in your NPI cylinder heads because of toomy95gtstang said:ok i have a 1996 mustang gt auto, stock gears, remanufactored japser motor with bbk shorty headers, bbk catted xpipe, pi intake manifold, mac underdrive pullies. i was lookin at gettin a cam but wasnt sure on which to get. i was leaning for Comp Cams like a xe270 with .550 lift but i see everyone posting the VT Stage 1 or 2 cams. i wanted a cam with not as big as a lift as .550 because later on i would like to run a turbo setup and that lift is kinda big. what are yalls suggestions?
sorry typed the wrong model comp cam, those were the ones i was just lookin at on ebay, those are for a 302
but i shouldnt have to get new valve springs since i have a new motor, only 2k miles on it so the springs are still good. but will the 262H cam be good for a N/A setup or for a turbo setup? i want to turbo the stang one day but i know there are "boost cams" and cams more for N/A so is a cam something id have to get when i do the turbo setup cuz i dont think there is a cam that is good for both
I know the feeling.96PonyGT said:hm.....maybe just PI cams for me then......I just want to do it right the first time around....what would you do? would doing stage
with new springs be a good idea or a waste or should I just go with stock PI cams?
I hate being tossed between mods for my car
my95gtstang said:now if i get those they wouldnt work with a turbo setup right? so id HAVE to get those custom cams
what about if i run a SC setup, same thing? custom cams or cams for a SC rather.
Either way you want camshafts that match your setup.my95gtstang said:anyone answer my previous questions?
Sure man you could go with the PI cams if want they are a96PonyGT said:yea, I figured spending the money on NPI cams might be a waste, im just thinkin if its expensive to put cams in then I
would go get some good ones the first time around, so there are no NPI cams that would be worth the money and to just go with
stock PI cams?
