Can I wax my car now?
Austinx56
Daphne Alabama
So it’s been exactly a month since I’ve gotten her outta paint, it has some spots and swirls that need to be buffed out, so I’m I safe after a month of letting it cure?
evilcw311
Most Evil Member!
Louisville, KY
Your going to get different varying opinions on this. In my honest opinion I’d ask the guy who did your paint. He’s the one that would have to warranty anything done to it. If you listen to someone else and then later needed warranty work it could cause an issue.
With that said, if the paint has had tons of sunlight and heat and has truly had time then it shouldn’t be an issue, but I stand by my statement above. Talk the the guy.
Paint job looks good
I would say wash it and shammie on it
Then the next month take it back to him and have him use a clybar on it
Austinx56
Austinx56
Daphne Alabama
Thanks for the info, I was told 4 weeks but after dropping 7k I’d kill myself if I ruined it. It has a 5 year warranty
Austinx56
Austinx56
Daphne Alabama
Yeah it only has about two spots where there’s orange peel after they did the cut and buff and some swirl marks I could do it myself but if the paint is under warranty should I just let them do it?
Better safe than sorry
Let them do it . They screw up it's on them
Austinx56
Austinx56
Daphne Alabama
It’s so tempting not to fix it yourself I just hate having my car away
NEURON
SOCAL
Don't wax until all fixed. Waxing is good, but keeping it clean is the most important I have been told by numerous painters.
The only issue with wax or sealants on fresh paint is the outgassing. You can get hazy clear coat is you seal in solvents that are trying to outgas through the paint. If you want to cut and buff the clear, this is a bodyshop technique, they've already done it, it won't hurt anything, as long as you use products for fresh paint that don't have sealants in them. Compound wouldn't, it's for cutting only, but as others have said if it has issues from the original cut and buff that the bodyshop did, why even think about working on it when you already paid them thousands to make it perfect. Just take it back.
myk
Sun diego
That is a gorgeous car. I'd never have to balls to drop 7K on paint but I can see it's totally worth it...
evilcw311
Most Evil Member!
Louisville, KY
$7k on a paint job is nothing anymore. That’s about the average cost of getting a total spray. Get into some of the higher end specialty colors and you can start climbing over $10-15k quickly
T's Convertible
